Guest dan4011 Posted August 29, 2006 Share Posted August 29, 2006 i got a set of some honeycomb 14x7 wheels for my 280z, having it all together we found out the front wheels wobble at higher speeds and it makes the steering wheel shake a bit, we got them balanced and upon further inspection it seems that the wheels arent centering right, because the hub wont line up on the wheel right (wheel not made for car maybe) so its hard to get the lug nuts to even out the tire right i guess. so my question is this: is there a place i can get lug nuts that will go deeper into my wheel than standard lug nuts to hold the wheel as straight as possible? thanks Quote Link to comment Share on other sites More sharing options...
veritech-z Posted August 29, 2006 Share Posted August 29, 2006 Is the hole on your wheel larger than the stud? You can get what are called "shank lug nuts" that fit down inside the wheel almost anywhere that sells vehicle accessories. A wheel shop would be a great place to start. Quote Link to comment Share on other sites More sharing options...
uh-oh Posted August 30, 2006 Share Posted August 30, 2006 where did u find those wheels at? im lookin for sumthin 2 use as a center cap. wen i got the car it didnt have them on it. Quote Link to comment Share on other sites More sharing options...
