LS1 240Z Posted August 30, 2006 Share Posted August 30, 2006 lets see if anyone on here knows this... LS1 stock rebuild solid ring on top beveled ring next, dot up, bevel down (i know these botom 3 are correct) oil ring spacer oil ring Quote Link to comment Share on other sites More sharing options...
Lason Posted August 30, 2006 Share Posted August 30, 2006 Are you asking if that is right? Quote Link to comment Share on other sites More sharing options...
LS1 240Z Posted August 30, 2006 Author Share Posted August 30, 2006 yes, nobody on LS1 tech knows. Quote Link to comment Share on other sites More sharing options...
Lason Posted August 30, 2006 Share Posted August 30, 2006 Sorry man, I havent ever got that far into an LS1. I know of a shop over here that builds performance LS1's though. Ill ask them on another board I frequent and shoot ya an answer as soon as I hear from them. Quote Link to comment Share on other sites More sharing options...
DaleMX Posted August 30, 2006 Share Posted August 30, 2006 yes, nobody on LS1 tech knows. It's always funny to read on that forum, everybody knows everything until you ask for something specific. The manufacturer's mark is supose to be facing up, that is for sure. I am not sure as to the order, but the LS1 performance book I have says that the tapered ring is in the second position so that leads me to the square ring being on top. Gaps should be rotated 180 and 90 degrees from ring to ring. Are you filing to fit? What gap are you going with? Quote Link to comment Share on other sites More sharing options...
mario_82_ZXT Posted August 30, 2006 Share Posted August 30, 2006 One of my friends dissassembled an LS1 with 13k miles on it (factory) and the rings weren't gapped 180* or 90* on all the pistons. He found it really weird. Just an FYI Mario Quote Link to comment Share on other sites More sharing options...
gearheadstik Posted August 30, 2006 Share Posted August 30, 2006 I just put new rings in my ls1...I can let you know tomorrow..if no one has by then..I'm at work tonight. Quote Link to comment Share on other sites More sharing options...
Lason Posted August 31, 2006 Share Posted August 31, 2006 One of my friends dissassembled an LS1 with 13k miles on it (factory) and the rings weren't gapped 180* or 90* on all the pistons. He found it really weird. Just an FYI Mario They dont stay 180 or 90. But for assembly purposes it help keep a seal. They will roatate while the motor is running. Quote Link to comment Share on other sites More sharing options...
LS1 240Z Posted August 31, 2006 Author Share Posted August 31, 2006 i put the square on top, the beveled one next with the dot up, bevel down, then oil rings, the two oil rings i put 180 off. the top to i put 180 of each other, and 90 off of the dot Quote Link to comment Share on other sites More sharing options...
gearheadstik Posted August 31, 2006 Share Posted August 31, 2006 Lason is right the ring spin over time...it does not hurt anything...What kind of rings are you using?? I could'nt find any from gm, I used perfect circle. I think you did everything correct, I could'nt find my box instructions but know the dot always faces up and if only one ring is beveled it's the second ring, which is usually a darker color. Quote Link to comment Share on other sites More sharing options...
LS1 240Z Posted August 31, 2006 Author Share Posted August 31, 2006 i got them from GM parts direct. around $145 to my door for a complete set. now that i know i got the rings all right im going to put the other 6 pistons in this weekend, along with putting in the cam, timing chain, oil pump and putting on the oil pan i need to get valve springs and headgaskets and pushrods and my motor will be all together.. i cant wait that reminds me, anybody buy multi layered steel headgaskets? if so where did you buy them from and how much. Quote Link to comment Share on other sites More sharing options...
gearheadstik Posted August 31, 2006 Share Posted August 31, 2006 If you ever need new rings perfect circle by dana are 129.00 and i used mls 75.00ea they are a little overbore but work geart for the money http://store.summitracing.com/egnsearch.asp?Ntk=KeywordSearch&DDS=1&Ntt=fog%2D923343910&searchinresults=false&N=+115 Quote Link to comment Share on other sites More sharing options...
