Slotted Crossmember - who's done it?
I can't remember who did this mod, but as I recall, it was to gain infinite adjustability in the bumpsteer curve. Fess up - was it you?
Oh, and while we're here, what's the closest SAE sized drill bit to a 14mm? Just right would be just right, but if I have to grind a little, I'll survive.
Thanks,
I've done it. But I also added stuff to make the height adjustable (and lockable other than just tightening the big through- bolt). The side-to-side position is also adjustable, and independent of the height adjustment. Unfortunately, that one is only locked down by tightening the through-bolt.
I don't have any good pictures of this set up. I may have some drawings though.
There's at least this thread on this subject: http://www.hybridz.org/cgi-bin/ultimatebb.cgi?ubb=get_topic&f=6&t=000549
BTW, 14mm is 8.81/16ths of an inch. So 9/16" is pretty close!
