ZX discs, which ones go w/ '82-83 calipers?
If you are writing about the rear brakes, yes, I think you chose the correct ones. I found the early brakes required a lot of offset in the rotor, and thus made the caliper mounting bracket hard to design. I instead used the later ones, which were easier (IMHO) to mount than the later ones (and lighter too). If you can get the turbo rear calipers, I believe the piston is slightly bigger than the N/A versions.
