Dan Baldwin Posted June 16, 2001 Share Posted June 16, 2001 I've bought '82-'83 rotors, but for some reason my brain keeps making me think I should've gotten early ZX rotors. So, put me at ease and tell me that with the Maxima brackets, I want the '82-'83 calipers AND rotors. Thanks, Quote Link to comment Share on other sites More sharing options...
blueovalz Posted June 16, 2001 Share Posted June 16, 2001 If you are writing about the rear brakes, yes, I think you chose the correct ones. I found the early brakes required a lot of offset in the rotor, and thus made the caliper mounting bracket hard to design. I instead used the later ones, which were easier (IMHO) to mount than the later ones (and lighter too). If you can get the turbo rear calipers, I believe the piston is slightly bigger than the N/A versions. Quote Link to comment Share on other sites More sharing options...
