Guest Landeros71 Posted September 16, 2006 Share Posted September 16, 2006 I got a 81 no turbo 280 the engine starts when is cold but when he gets warm he just off, i already change spark plugs air filter, fuel filter, and still the same way, i need help wath i cand do or how can i check the Air flow Meter i think is not working cause i have alot of gasoline in the spark plug, and also noisy explotions in the intake. Quote Link to comment Share on other sites More sharing options...
JK_DC Posted September 16, 2006 Share Posted September 16, 2006 Did you check the cylinder head temp sensor or water temp sensor? It could be telling the ECU that it is still cold and making the mixture too rich at operating temp. Quote Link to comment Share on other sites More sharing options...
roger.svoboda Posted September 16, 2006 Share Posted September 16, 2006 change them first. Quote Link to comment Share on other sites More sharing options...
280zwitha383 Posted September 16, 2006 Share Posted September 16, 2006 Will it start back up after it dies? If so it's more than likely the ignition module. Gotta hate 'em. Quote Link to comment Share on other sites More sharing options...
Guest Landeros71 Posted September 16, 2006 Share Posted September 16, 2006 how can i chek it? i guess i need an ohmeter, an also they aresome tests i can do to the sensors before change them? Quote Link to comment Share on other sites More sharing options...
JK_DC Posted September 17, 2006 Share Posted September 17, 2006 http://carfiche.com/manuals020/cars/ That is a link to the service manual for an 82, it should be close. Has data on everything. If it doesn't have a download link you have to try again the following hour. Yeah you need an ohm meter, the resistance should decrease as it warms up. Page EF&EC-56. Quote Link to comment Share on other sites More sharing options...
