evildky Posted September 19, 2006 Share Posted September 19, 2006 so I just got a copper headgasket form IPP and it's solid!? currently running a multilayer Nismo and got this one for another build and it's solid!? also comes with a tag that says to apply a thin layer of pipe dope around water and coolant passages, should I just coat the whole thing with copper spray? or try some sort of sealant around the passages? not sure what to think of the solid headgasket, anyone else running a solid headgasket? Quote Link to comment Share on other sites More sharing options...
zguy36 Posted September 19, 2006 Share Posted September 19, 2006 Copper gaskets are solid. Why did you switch from the steel to the copper? I ran a copper head gasket for a few years and the thing used water from the get go. The first ten minutes of running, I had water pouring out between the head and block (used copper coat gasket spray). I went to the local machine shop and they recommended Hylomar spray. This worked better, but still ended up using some water. The head gasket later blew, so I switched to steel. Quote Link to comment Share on other sites More sharing options...
evildky Posted September 19, 2006 Author Share Posted September 19, 2006 my current engine has the multilayer nismo gasket which I recall as being copper? I really don't remember just that it was multilayered with crush rings around all the passages, which might have some sort of a leak now as I've been informed that when racing when I let off the gas I emit lots of white smoke the new gasket is for a different engine in a differnt car, also an L28ET and I'm hoping to build a fresh 3.0 bottom end this winter Quote Link to comment Share on other sites More sharing options...
510six Posted September 20, 2006 Share Posted September 20, 2006 Copper gaskets are generally used in conjuction with O rings and will always leak a little water.I had one years ago on a turbo L series 4 cyl and it worked OK with copper tack on it with O ringed cylinders , but it still leaked a bit of coolant.I ran some Bars all stop leak , the kind that looks like coffee grounds and that helped a bunch.You might try some of this http://www.headgasket.com/contents/_GWG%20P_5_label%20v1.pdf Quote Link to comment Share on other sites More sharing options...
