Guest dan4011 Posted September 20, 2006 Share Posted September 20, 2006 just a quick reference question. i know for the most part the larger the turbo, the more air it can move with less heat, and from experience ive seen that smaller turbos seem to spool up faster and are alot more respondant, but just push hot air at higher boost levels. so my question is, at low boost levels, is it better to have a smaller turbo and are you going to gain anything from a larger set up. reason im asking is i have a t3/t4 hybrid on my n/a turbo, car isnt going to see over 12psi boost. thanks guys. and yes i know, i need to read maximum boost, anyone have an extra coppy they wanna sell? Quote Link to comment Share on other sites More sharing options...
spork Posted September 21, 2006 Share Posted September 21, 2006 It depends on the trim and specs of that hybrid turbo. With a properly set up hybrid, the car will run good, but with the wrong one, The car may not come alive until you get into the higher boost levels. Quote Link to comment Share on other sites More sharing options...
Lunar240z Posted September 21, 2006 Share Posted September 21, 2006 check Amazon.com for it used. i got my copy that was practically new for like $15 Quote Link to comment Share on other sites More sharing options...
Noddle Posted September 22, 2006 Share Posted September 22, 2006 Lunar240z said: check Amazon.com for it used. i got my copy that was practically new for like $15 Try a Library, thats where I'm getting my copy from, cant afford the $75 AUS they want for it here in Australia, since you can buy it for $23 US from amazon. Quote Link to comment Share on other sites More sharing options...
