Will this motor make good power?????
Guest V8Z
I found roller lifters, roller rockers and a cam shaft combo deal for a great price and wanted to see if it sounds like a good set up or not, any fore seen problems and if the cam will work well with the fast burn heads. cam is a pro comp as is the other components and the cam specs are listed below.All this is retro fit for the older blocks. What HP do you think this will obtain?????Spending alot of money and want to make sure before I purchase all this stuff.
My engine part # is 10067353 and the specs are:
Horsepower: 249 HP @ 5,000 RPM At Stock set up
Torque: 304 Ft/Lbs @ 3,500 RPM At Stock set up
Compression Ratio: 8.50 to 1 At Stock set up
Block: 4 – Bolt, 2 Piece Rear Seal, 4.000†Bore
Crankshaft: Cast Nodular 3.480†Stroke
Heads:GMPP Fast burn 62cc ( replaced cast iron heads)
Valves: 2.000†/ 1.550"
Camshaft lift: 0.502†/ 0.510†Hydraulic (replaced OEM factory cam)
Intake: Eldelbrock Dual plan vortec style
Carb: Holley 670cfm
Camshaft Specification Table
Part Number 12-423-8
Engine 1955-1998 Chevrolet
262ci-400ci
8cyl.
Grind Number CS XR276HR-10
Description
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.502 0.51
Duration At 0.006 Tappet Lift 276 282
Valve Timing At 0.006
Open Close
Intake 32 64
Exhaust 75 27
These Specs Are For The Cam Installed At 106 Intake CL
Intake Exhaust
Duration At 0.05 224 230
Lobe Lift 0.335 0.34
Lobe Separation 110
Well at first I thought 400hp with those heads, compression ratio, and cam was waay too much. However, I'm sure you've seen the articles where this cam or something like it was swapped into a vortec engine (with roller cam and carb.) and made something to the tune of 400hp give or take. The fast burn heads I ASSume flow better than the vortecs so I guess that's possible. Your 8.5:1 might hurt you a little, however please let us know if it doesn't because I'm curious. BTW, Desktop Dyno gives you 349hp at 5k and 408tq at 3.5k with the exact setup you have including large tube headers.
