boodlefoof Posted September 25, 2006 Share Posted September 25, 2006 My grandparents had somebody coming and stealing gas from their cars awhile back. Just started parking them really close to each other with the fuel doors facing one another such that you couldn't open them. I do like the diesel idea though! Quote Link to comment Share on other sites More sharing options...
Guest Mike Posted September 25, 2006 Share Posted September 25, 2006 I wonder if you could dissolve the sugar in a galon of boiling hot water... saturate it... then mix it with four galons of gasoline? Myth busters sux.. I know sugar can destroy a fuel system. I have had to replace more than one complete fuel system for customers. One on a brand new Z3.. Quote Link to comment Share on other sites More sharing options...
veritech-z Posted September 25, 2006 Share Posted September 25, 2006 That would probably work great until it cooled off and settled out to the bottom... Quote Link to comment Share on other sites More sharing options...
Guest Mike Posted September 25, 2006 Share Posted September 25, 2006 Not all of it would settle... only what the cooler solution couldn't hold. That would probably work great until it cooled off and settled out to the bottom... Quote Link to comment Share on other sites More sharing options...
kilten_one Posted September 25, 2006 Share Posted September 25, 2006 Not all of it would settle... only what the cooler solution couldn't hold. you would end up with a fair amount of sugar crystals if you didnt move the solution around much there wouldnt be all that many and they would end up larger. your best bet would be to let it cool in a stand mixer set to low you should also might want to run it through a mesh strainer to remove any large chunks that might clog their hose Quote Link to comment Share on other sites More sharing options...
Guest Mike Posted September 25, 2006 Share Posted September 25, 2006 Yup... that's right. Maybe TWO galons of saturated sugar water to TWO galons of gas, heh, heh... That'll teach em' to steal:flamedevi you would end up with a fair amount of sugar crystals if you didnt move the solution around much there wouldnt be all that many and they would end up larger. your best bet would be to let it cool in a stand mixer set to low you should also might want to run it through a mesh strainer to remove any large chunks that might clog their hose Quote Link to comment Share on other sites More sharing options...
