LSD from 1988 300ZX
I have found an R200 LSD from a 1988 300ZX. It is the clutch type. I have some questions. Can I use the half-shafts from an earlier R200(That's what is in the car now)? It it as simple as popping out the 300Z half-shafts and popping in the 280Z half-shafts. Can I use the early style rear differential cover? I know that there is a special brace available that clears the finned cover, but I don't want to buy it immediately. What is the break-away torque of the 300ZX units?
Thanks,
Dan McGrath
I used my stock 240 halfshafts, but some have reported that the R200-specific 280Z halfshafts are required (they're shorter). Mine work fine, though. You'll have to swap the input and output flanges with ones from an R200 280z. You have to use a plain cover in place of the finned one, or modify the moustache bar and rear crossmember that runs aft of the diff. My LSD measured 23 lb-ft breakaway, and I think the factory spec is 18-30. You can shim if you want more.
