280Z Turbo Posted October 10, 2006 Share Posted October 10, 2006 First of all, what size piping should I have? 2" or 2.25"? I know 2" is better for response, but 2.25" would flow a larger volume. I am leaning towards 2" because it is easier to work with and because the TB and turbo are both 2". Here's what I have: 70's crash bumper removed for easy access. That pipe seems to be at a bad angle for me, but would a 90 degree coupler be okay? I'm not sure if that would even work, I may have no choice but to mod the end tanks. Where would I go to modify them, though? I don't know anything about welding aluminum so I couldn't do it. How could I make it work? The return pipe to the TB is coming from the passenger side. Notice the aluminum pipe on the end of the J-pipe...I need that 1" bung on there for my Saab recirculation valve. That presents another problem of where can I recirculate it to before the turbo Also going to need to do something about the stock POV (shim it?) and dump valve. How do I curve the return pipe around my radiator hose? Passenger side hole. Kind of a tight space...not sure about brackets yet or where to mount them. Will this be okay for an air cleaner position? It's a lot lower than before and I'll have to wrap the 3" pipe around the frame rail and up to the turbo. I think I may run the oil cooler on the opposite side, but the oil cooler hoses are stiff as hell and I have no way to mount anything. I may go with a custom one, but I can't find a nice small one like the stock 280ZX one. Also, I have been told that I could mount the oil cooler inside the engine bay, but it would reduce efficiency by about 20%. The Evo I/C itself. The fins on this thing are VERY fragile. Is there anyway to protect them? Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted October 10, 2006 Share Posted October 10, 2006 i was gonna run a EVO intercooler but i went NPR instead cuz i snagged a deal.. looks very cool... I would use some 90 degree silicone bends for that one.. Quote Link to comment Share on other sites More sharing options...
280Z Turbo Posted October 12, 2006 Author Share Posted October 12, 2006 i was gonna run a EVO intercooler but i went NPR instead cuz i snagged a deal.. looks very cool... I would use some 90 degree silicone bends for that one.. I'm not sure if those couplers will work, because of the angle of the inlet and outlet. I wish they weren't so expensive! How did you guys that have done this before figure out which and how many U-bends to buy? Quote Link to comment Share on other sites More sharing options...
Guest thatoneguy Posted October 13, 2006 Share Posted October 13, 2006 me beeing new and all...... what about running it over the rail or making the hole bigger Quote Link to comment Share on other sites More sharing options...
randy 77zt Posted October 25, 2006 Share Posted October 25, 2006 i used 2 1/8 summit u-bend for my hot side piping.i reclocked the turbo and ran it under the pan and into the ic through rh hole in the radiator core support.i used some old ford powerstroke truck ic tubing for the cold side. Quote Link to comment Share on other sites More sharing options...
zguy36 Posted October 26, 2006 Share Posted October 26, 2006 welcome to fab work.... if you are going to put something in a car that it didn't come with, then you are going to have to cut, bend, and fab the @#$^ out of everything in there. Buy some bends, buy a good sawzal and a bunch of tubing and go to town. There is no easy fix. Sorry! Quote Link to comment Share on other sites More sharing options...
HadesOmega Posted October 27, 2006 Share Posted October 27, 2006 Should have room for an oil cooler I did http://www.paper-momo.com/hadesomega/carz/Pictures/Sic16.jpg yeah that's a pretty shitty turn signal job here's where I put my filter and AFM http://www.paper-momo.com/hadesomega/carz/Pictures/Sic19.jpg but it look like you have something where I have mine, I took my AC compressor out. I would stay with 2 inch, but it depends on how much boost your planning to boost. More boost bigger pipes. Quote Link to comment Share on other sites More sharing options...
