Help with clutch/Tranny using 2jzgte help!!!!!
Guest dini_the_owl
Guest dini_the_owl
Hi,
Could anyone tell me this please as i am a little confused.
If i were to use a 2jzgte motor, i have 3 options for gearbox.
1 use the v160 tt 6 speed box
2 use a r154 gear box from a mk3 supra, and use the w58 bell housing off n/a mk4 supra
3 use a straight w58 box
the question i need to know is if i go with the w58 box, would i have to run the n/a supra clutch+flywheel system. or is it possible to use a 2jzgte flywheel and clutch,i have got both systems to hand and the 2jzgte flywheel is slightly larger in size and 2jzgte clutch will not fit the n/a flywheel due to the size and pin locations. So if i changed to a 2jzgte flywheel and clutch system how or is it possible to use the w58 box, as the w58 clutch is a push motion clutch not a pull motion like the supra 2jzgte... even if i had the clutch slave cylinder and pitch fork off a 2jzgte....
Could i do it this way or am i stuck with the n/a(2jzge) clutch if i use the w58 box.
please help anyone with suggestions
andy
