racerx260 Posted November 9, 2006 Share Posted November 9, 2006 Have 83 Turbo And Ecu In 260. Has Been Truoble Free For A Year. Now It Runs Great Above Idle . But No Idle. So Far I Have Changed The Following. Ecu, Air Flow Meter, Temp Sending Unit, Fuel Regulator,checked Timing, Changed Coil And Ignighter. Any Ideas. On The Turbo The Ecu Controls Idle. Could It Be The Throtle Body?help! Daily Driver Quote Link to comment Share on other sites More sharing options...
bherd Posted November 11, 2006 Share Posted November 11, 2006 I am just firing up an '83 turbo and had to position the idle switch to be engaged when in idle by loosening the mtg screws and rotating. I used an ECCS piece of test equipment I got off ebay to check quickly if the idle switch was set. Do you have the vacuum modulator part of the turbo version? Bil Quote Link to comment Share on other sites More sharing options...
