mystery part removal ??? can i does it matter?
neorazz
ok i have this blower in my 83 280zx
http://i5.ebayimg.com/02/i/08/90/45/1f_1.JPG
is this just for cooling the actual injetors ?
i took out the stock fuel trombone and put in a fuel rail you can see the rail thru the turbo vent in the hood so i would think enough air should be passing over the area at speed
so unless you were gunning it and then dead stopping
what does anyone think ? ok to remove i havent seen this in any of the motor pics but im not sure if other years needed it
also i may get larger injectors what other vehicles have ijectors with more cc that fit the l28 ?
i though i read somewhere the neons
i'm looking to go to a megasquirt system and if i can find the right injectors ill see if i can get the harness section too or are injector harness connectors similar ?
