Nags Posted November 17, 2006 Share Posted November 17, 2006 Hello, I am curious as to what you gents would do in my situation... Basicly I have a megasquirt unit left over from a past project and want to make use of it on my 75 as it currently barely runs due to a failed airflow meter. My first plan was to get a 83 turbo dissy and use that for my tach signal (unfortunatly I am having a tough time finding one, even though I work at a nissan wrecking yard, i found a turbo L28 but the dissy is missing and so is the oil filter setup which i wanted to grab off it ) SO now I am thinking of finding a edis 6 setup off ebay or some other source and using that instead, i am wondering a few things about the setup though. 1. Whats the best way to go about mounting the trigger wheel?? 2. What Trigger wheel setup do i need (how many missing teath, 16 tooth wheel??? ect) 3. Where can I buy the proper wheel setup i ll need 4. Is benchtesting the setup accualy nessecary?? I know the obvios answer is to go with the edis-6 but although it can be incorporated onto pritty much anything it might be alot more of a PITA then i want it to be. Thanks, Joe Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted November 17, 2006 Administrators Share Posted November 17, 2006 Hmmm. You didn’t search much here on Hybrid did you?... Here is a little help with LOTS of details and pics answering the questions you asked… Extensive EDIS and L-6 info… http://forums.hybridz.org/showthread.php?t=103781 The EDIS Test Bench.. http://www.msextra.com/viewtopic.php?t=14920 DIS ignition and EDIS http://forums.hybridz.org/showthread.php?p=666236 My personal up and running EDIS project… http://www.msruns.com/viewtopic.php?t=15436 Coil packs… http://forums.hybridz.org/showthread.php?t=115481 Hope that helps… Paul Quote Link to comment Share on other sites More sharing options...
