gretchen/jason Posted November 19, 2006 Share Posted November 19, 2006 I had a set of SBC 350 heads ported and such 3 angle valve job the exhaust valve for instance is what im concerned about as im running a super charger and the intake is of little concern So id like to ask how much will i notice the port job the cfm flow on a bench flow machine took a 1.5 exhaust valve the first test showed 185 cfm with a 490 lift i believe it was measured in inches of mercury to acomidate the high altitude where i live . So after some grinding it went from the above stated flow 185 cfm to 235 cfm with the same 490 lift i assume its alot even though the numbers dont seem to different any remarks are welcome Quote Link to comment Share on other sites More sharing options...
MONGO510 Posted November 19, 2006 Share Posted November 19, 2006 Man, you got to use some punctuation! Quote Link to comment Share on other sites More sharing options...
