Guest Anonymous Posted March 8, 2001 Share Posted March 8, 2001 I have just received my cooling fan I ordered from Summit, (flex-a-lite Twin Scirocco). Well the mounting brackets fit perfect IF I can go with self taping scews into the side tanks of the rad. What do you all think, do you think it would leak coolant if I did this? Thanks Tom ------------------ 87 RxV8/TurboII/2+2 Chevy 350/390hp, T-5(B&M shortthrow) Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted March 8, 2001 Share Posted March 8, 2001 Your kidding right? Yes it would definetly leak! Don't forget the cooling system is under pressure, any small leak will stream out with force. ------------------ http://members.tripod.com/~SnowSurfer/mikekz1.html Quote Link to comment Share on other sites More sharing options...
383 240z Posted March 8, 2001 Share Posted March 8, 2001 Huge leak dont do it I have the flex-a-lite 150 and I mounted it with these cool zip tie type mounts that worked great on my 87 RX-7 that I autocross regulary with no problems ------------------ rx7260z@yahoo.com Speed Power Performance& Style. What else is there? Quote Link to comment Share on other sites More sharing options...
Guest kc6wfs Posted March 8, 2001 Share Posted March 8, 2001 Ya don't drill anything into the tanks. You will regret it. Look at the pics of my fans I put on. Look how it's mounted. You could do the same for about 10.00 in hardware. Also I would not use the plastic through the rad holders. The torque from the fan will cause leaks over time. http://www.geocities.com/kc6wfs/240z.html ------------------ www.geocities.com/kc6wfs/240z.html www.NitroPhotos.com Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted March 8, 2001 Share Posted March 8, 2001 Thanks for the advice. I was also thinking about using zip ties also, I was just concerned with the heat that comes of off the rad (would it melt the ties?). Tom Quote Link to comment Share on other sites More sharing options...
DavyZ Posted March 9, 2001 Share Posted March 9, 2001 No, the ties won't melt... Mounting a radiator is all about brackets and such that don't connect via screws or whatnot into the tanks. Go to a wrecking yard and see how most cars mount the radiators. Then make an informed decision and go for it! Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted March 9, 2001 Share Posted March 9, 2001 Thanks I'm going to go with the zip ties. ------------------ 87 RxV8/TurboII/2+2 Chevy 350/390hp, T-5(B&M shortthrow) Quote Link to comment Share on other sites More sharing options...
383 240z Posted March 10, 2001 Share Posted March 10, 2001 I did not use regular zip ties the ones I got are from hayden they are straight with quarter sized lockwashers and foam pads for between the fan and fins. They were sold with the add on transmission coolers in the local discount auto parts store. ------------------ rx7260z@yahoo.com Speed Power Performance& Style. What else is there? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted March 10, 2001 Share Posted March 10, 2001 I am concerned that this may not be enough fan for you. Is this a street car? Those fans are intended for drag race use. Bring it to temp. run it then shut it down. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted March 10, 2001 Share Posted March 10, 2001 It is my daily driver but I am also going to drag it. You don't think it will keep me cool? Tom ------------------ 87 RxV8/TurboII/2+2 Chevy 350/390hp, T-5(B&M shortthrow) Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted March 11, 2001 Share Posted March 11, 2001 It will depend on you weather, but I really think you'll have problems. I mentioned your post to a friend of mine and before I could finish he said that you'll have cooling problems. This really isn't the fan for you. Summit has a very good return policy, and I would look at the FLX-210 if you have the room. It won't flow quite as much as the 150, but it covers more surface area and will cool more thoroughly. Yes, they are a lot more money. If you decide to return the fan and have any problems E-Mail me personally and I'll see if I can help. No Promises Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted March 11, 2001 Share Posted March 11, 2001 The 210 is the first one I bought but it was to big, to wide and the 150 is to thick. **** now I don't know what to use. Any other suggestions? Thanks Tom ------------------ 87 RxV8/TurboII/2+2 Chevy 350/390hp, T-5(B&M shortthrow) Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted March 11, 2001 Share Posted March 11, 2001 My next choice would be the DER-16516 It flows 1900 CFM. There are some very good things being said about a Ferd Taurus 2 spd fan on the Ferd swap section. I really like what I see and hear about them. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted March 12, 2001 Share Posted March 12, 2001 I'm only working with 22inch wide and about 3inch thick, the scirocco fan is rated at 1800 cfm and it fits perfect on my rad. I wonder what the messurements on the tarus fan are? What if I were to mount a fan in front of the rad(more room)? Would it be to restricted? Does anyone know how much air approximately is moved by a 15inch pulley driven fan at idle? This would give me a good idea what type fan would work. Tom ------------------ 87 RxV8/TurboII/2+2 Chevy 350/390hp, T-5(B&M shortthrow) Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted March 13, 2001 Share Posted March 13, 2001 I don't know the CFM's of OE fans but they are far more than any electrical. Placing a fan on the front is OK but not nearly as efficient as placing it on the back side. Can you get a thicker fan if you offset it? Place the fan to the right or left of center. Quote Link to comment Share on other sites More sharing options...
