fl327 Posted October 29, 2001 Share Posted October 29, 2001 hey will the rotor(with hub) from 280z bolt up to a 240? and do they use the same wheel bearings, i was looking up parts prices and the 280z stuff is a lot cheaper than 240, are they interchangable???? it would help me save some bucks and id be really grateful. thanks guyz, keep rockin Quote Link to comment Share on other sites More sharing options...
Guest scca Posted October 29, 2001 Share Posted October 29, 2001 yes....... as long as you dont mix 240 and 280 hub and rotor, the complete rotor/hub assy will interchange on any year 70-78. Quote Link to comment Share on other sites More sharing options...
R0N Posted October 29, 2001 Share Posted October 29, 2001 Hi Mike... Any advantage in doing the swap? Thanks, Ron Quote Link to comment Share on other sites More sharing options...
Guest scca Posted October 29, 2001 Share Posted October 29, 2001 None...... its the same overall thing.. only difference is between the hub and rotor offset. the outer hub face is in the same place. the 280 hub is a stronger piece IMO. whether its needed or not thats for engineer to say. 240 hub is (lets say) 8mm offset and rotor is 24mm 280 hub is 16mm and rotor is 16mm . just 2 different ways to achieve the same end result. Quote Link to comment Share on other sites More sharing options...
R0N Posted November 6, 2001 Share Posted November 6, 2001 Thanks for the update Quote Link to comment Share on other sites More sharing options...
Guest RXO510 Posted November 7, 2001 Share Posted November 7, 2001 Learned some great info about the rotors, hubs and bearing today. Thanks You just never know. Quote Link to comment Share on other sites More sharing options...
