Guest Daddyrick Posted November 15, 2001 Share Posted November 15, 2001 When I went to install my S&W roll cage (8 pt), I realized it was going to involve a lot of custom cutting and fitting to get it right. So I went and bought several sections of similar diameter PVC pipe. Test cuts for the various angles were a breeze using the PVC. No need to worry about mistakes when making the mock up with PVC, if you make a mistake, just cut another piece! After a proper fit is determined, just copy the pattern to the real thing and in no time you are finished. Quote Link to comment Share on other sites More sharing options...
Tim240z Posted November 15, 2001 Share Posted November 15, 2001 When I did mine last weekend, as I mentioned in an earlier post, I had to do a lot of fabbing....I used the core of a paper towel roll to get the angles right, then I just cut it long ways and wrapped it around the tubing and transfered the template with a marker and cut...worked really well, but start saving your paper towel rolls NOW!!! Cheapest way I could think of, and the transfer is 100% accurate. Tim Quote Link to comment Share on other sites More sharing options...
