24OZ Posted December 6, 2006 Share Posted December 6, 2006 Hey guys, Let me be the first to admit that I have read and re-read the MS bible but I am still having problems. So far i have a preassembled MS I with V3.0 board purchased from DIYAutotune. I also asked them to perform the mod so i can directly fire the coil from my MS. I have therefore not Flashed the firmware on the ECU since they state that this is what you need to do to perform the mod.. See... Using the MS-I PCBv3 with MSnS-E firmwarehttp://www.diyautotune.com/tech_articles/how_to_megasquirt_your_280zx_turbo.htm The first problem which I have encountered is that I have downloaded Megatune and i have also downloaded a friends MAP and when I open it, Megatune opens and says..." "although the file was read successfully, there were 477 warnings written to the audit.log file, you may want to review that first befire you send and burn the data." How does one review the Audit log? I have tried opening it by going into the folder but when I open it I cant seem to find how it is reviewed. I have also tried deleting it to start over again, and it deletes only to reappear once Megatune is run again. I have tried deleting it many times and low and behold it reappears. I also plugged in my MS 1 into my PC with the Stimulator connected and I received the following message: "Controller Code Version does not match signature in Megasquirt-I.ini (see Audit log for where the above file was found) Expected "0x14" (found in ini file) Received "" (from controller) Table corruption may occur, this is usually a very serious problem Terminate Megatune now?" Please can someone help me decipher, in lay mans terms, what exactly is going on and what I should do next. Thank you. Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted December 6, 2006 Share Posted December 6, 2006 It sounds like you have MegaTune configured for the standard Megasquirt code instead of MSnS-E. You'll need to change which code version you are using in the Megatune Configurator. Quote Link to comment Share on other sites More sharing options...
trippintl0 Posted December 6, 2006 Share Posted December 6, 2006 In your .ini files for megatune, you have to set it for MSnS-Extra. It's either custom.ini or settings.ini, can't remember off the top of my head. Also, there are like two copies. You only edit a certain one. There is a .BAT or program you can run that should open up the program to edit the correct config files. Quote Link to comment Share on other sites More sharing options...
24OZ Posted December 6, 2006 Author Share Posted December 6, 2006 Thank you very much guys. I uninstalled Megatune and you were correct, I did not have it set to MSN Extra on the Code Variant section , I have now set it to MSN Extra. I have gone down the list and made the relevant changes to the other setting on that page also and pressed SAVE! But now, when I double click the Megatune icon on my desktop I get a pop up warning box. "ERROR:Megatune.ini:0034 - The included file 'MSnS-extra.ini' could not be opened. MegaTune is terminating." It will now not open MegaTune for me, unless I Uninstall and reinstall it. Help! Quote Link to comment Share on other sites More sharing options...
24OZ Posted December 7, 2006 Author Share Posted December 7, 2006 Ok my bad, i worked out what I did wrong.. I never activated the msns-extra.ini.029C. This has been done now and I only have 39 warnings written in the Audit file, so getting there.... Quote Link to comment Share on other sites More sharing options...
woldson Posted December 7, 2006 Share Posted December 7, 2006 nice systematic approch! Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted December 7, 2006 Share Posted December 7, 2006 24OZ, Some downloads of MegaTune do not have the latest INI files. The 029C will be the wrong one for yours if it was a recent order. You'll need the 029q INI file, available from the MSnS-E manual: http://www.msextra.com/manuals/MS_Extra_Manual_Index.htm The download link is at the bottom of the page. Quote Link to comment Share on other sites More sharing options...
24OZ Posted December 7, 2006 Author Share Posted December 7, 2006 Thanks very much Matt, very much appreciated. I'm sorry guys for the unsystematic approach at times, it is very overwhelming for me but the more i read, talk to people, and play around the better it becomes. I'm not really that great with computer technology so this is a major mountain for me, and thanks again for your patience. I am a quick learner though and have every will to conquer this mountain... Quote Link to comment Share on other sites More sharing options...
mobythevan Posted December 8, 2006 Share Posted December 8, 2006 I'm sorry guys for the unsystematic approach at times If his comment was a sarcastic one it was inappropriate. We have all been overwhelmed and asked a lot of questions at some. We always need to remember what it was like when we started and use a nicer approach with new people. That keeps everyone interested in the hobby and its all about having fun. Good luck with the rest of your install. I have made sarcastic comments also, I am working on that. Quote Link to comment Share on other sites More sharing options...
