Neon coil packs for EDIS
mobythevan
  • Administrators
Has anyone used neon style 4 post coil packs for an EDIS setup? Did it require a single wire to trigger all 4 or 2 wires, each firing 2 posts?
Hi Moby,
Sure have, on a 510...
2 triggers, each firing 2 posts, same-same as the Ford coil pack.
Primary resistance was within .1 ohm of Ford.
  • Administrators
Ron, did you use the actual EDIS module to trigger the coil pack or did you use Megasquirt itself to directly fire the coil pack through the VB921 transistor?
I used EDIS to drive the pack, with MS running EDIS.
Spill the beans... what are you up to? :)
