Dave's Racecar project 240Z
Hey guys,
Here are the specs on my car as it stands and a blurb about it at the bottom.
Details:
Car:
Model: 240Z
Year: 1973
Colour: BMW Navy Blue (crows feeted to hell)
Front bar: Not standard (?)
Engine:
L28: Block F54, Head P90
Compression: 7.4:1
Cam: Crow #58643 Intake: 212 deg 0.075" dur, 0.480" lift, Exhaust: 210 deg 0.075" dur, 0.495" lift
Pistons: Standard
Rods: Standard
Crank: Standard
Displacement: 2753cc (Standard).
Oil cooling: Earls thermostat to 235x147x50mm Serck cooler.
Balancer: Custom Chris Wood built using BMW Inline 6 balancer.
Driveline:
Gearbox: FS5W71C S14 SR20DET 5-speed
Clutch: 5-puck cerametallic with 1110kg pressure plate
Diff: Locked 3.54:1 R180
Driveshafts: Standard *cough*
Tailshaft: Shortened with Dana Spicer uni-joints
Fuel System:
Tank: Standard
Lift pump: Carter 110gph
Surge: CM510 alloy around 1-2 litres
EFI pump: Bosch 044
Fuel feed line: dash-8 (1/2" ID) line
Fuel rail: custom
Injectors: 460cc N/A S5 RX7
Regulator: Bosch adjustable rising rate
Control/Ignition:
Type: EFI - fully sequential injection
Computer: Autronic SMC v1.99-2
Distributor: Scorcher custom hall-effect
Leads: Sorcher 8mm induction
Coil: Bosch 716HEC transformer type
Ignition Module: Bosch
Induction:
Manifold: Standard 280zx EFI
Throttle body: Ford XF Falcon 65mm
Piping: 2.5" stainless
Intercooler: ARE 520x300x90 bar and plate
Turbocharger: 620hp Garrett GT35R (0.82 turbine housing)
Exhaust:
Manifold: Custom Ian Rowlerson: stainless, tigged, tuned length, split pulse collector, external wastegate flange
External wastegate: Sub-zero 55mm dumping via a 2.5" screamer pipe
Exhaust: 3" mandrel bent mild. No mufflers. Ends just behind diff
Suspension and Wheels:
Springs: Lowered Kings progressive all round
Shocks: Gabriel POS, don't ask me why.
Sway bars: Whiteline adjustables all round
Street Wheels: 15x6.5 Starion Turbo with matt black centres.
Street Tyres: 195/60R15 Yokohama AVS
Race Wheels: F: 16x7 R: 16x8 Simmons B45
Race Tyres: 225/50R16 Kumho Ecsta V70A
Performance:
Power: unknown as yet
0-100kph: ~4.8sec
Quarter Mile: 12.83 @ 115MPH, 10psi, 195 tyres, open diff.
Calder: 1:11.6
Blurb:
I have a navy blue 240Z that I purchased from a friend of a friend.
Originally brought with blown head-gasket I drove it with the stock L24 and flat-top SUs ( :( ) until the SUs decided to develop a flatspot from between 1% and 80% throttle. Holding the throttle anywhere inbetween those two resulted in massive overfueling, a black plume of smoke three lanes wide on the freeway, half a rear muffler and a subsequent police detective motivated pull-over.
After several 65 mile going 100kph->110kph, clutch, roll down to 100kph, repeat, I sourced a supercharged L28 replacement. After some clutch dramas during the install I drove the car like this for 6 months or so while I gathered together parts for a turbo conversion.
Then in early 2005, after breaking the gear selector linkage on the 280z 5-speed in there I took the car off the road to do the conversion.
After much saving and what-not I got the car running again in the specs above (after blowing out the countershaft front bearing in the 240Z gearbox
I put in the slightly beefier SR20 gearbox which seems to be holding).
I have had the car put on hold while I moved to the US, and am working on getting it over here so I can continue its development. These days most of my time is spent wishing it was here and planning/saving for the modifications I have got in mind when that day comes. The car, whilst borderline streetable in its current state, is destined to be a trailer-queen. I know it has a long way to go, so please no flames about being a try-hard racer, I am working on it. :)
The engine-bay when the conversion was almost finished. Have since added heat shielding and oil catch can.
My first time out on the track, also here in video: http://video.google.com/videoplay?docid=-3267393565625239905&q=datsun+240z
Me madly trying to fix the rear brake lines. I finished the rear disc conversion exactly 5 seconds before leaving for the track day. When I got there I realised I'd messed up a braided rear line to I had to redo it. I also forgot the bleeding tools so did the track day with the brake pedal on the floor. :)
My first time at the drags, ran 12.834 @ 115MPH on 10psi with an open diff and hard 195 tyres:
My err.. custom centre console from alu. Dodgey but it works. The two hoses you see are for my detonation detectors
As she sits at the moment, all by her lonesome. :(
