jimbo5670 Posted December 24, 2006 Share Posted December 24, 2006 i have a megasquirt v 2.2 running fuel only with the normal firmware, and it was working, from what i could gather. I then tried to hook up a maniforl air temp sensor to it, and next time i turned it on, nothin showed on the laptop, saying something like do you want to work offline. I have no idea what happened, any ideas on how to get it working again would be greatly approciated. thanks, matt Quote Link to comment Share on other sites More sharing options...
z-ya Posted December 26, 2006 Share Posted December 26, 2006 Why were you running it without an IAT? Do you have a stimulator? Quote Link to comment Share on other sites More sharing options...
trwebb26 Posted December 26, 2006 Share Posted December 26, 2006 Check the resistance across the sensor. Stick it in the freezer and read the resistance. It will tell you if the sensor is good or not. If you are running "offline" - then you aren't connecting to the megasquirt at all - we need to concentrate on that problem first. Check the powers and grounds to the megasquirt and get the connectivity issue sorted out first. Quote Link to comment Share on other sites More sharing options...
