Guest 400 ci 280z Posted December 4, 2001 Share Posted December 4, 2001 i just realized that when i jacked the right side of the car up the passanger door shifted up (to the point that i couldnt open the door). could this be because my frame rails are weak? or something else. also does anybody know how to take those chrome drip rails off with out cutting them off? Quote Link to comment Share on other sites More sharing options...
Tim240z Posted December 4, 2001 Share Posted December 4, 2001 Most cars will twist when jacked on one side. If it stays that way after you let it down, then start worrying. Tim Quote Link to comment Share on other sites More sharing options...
Guest 400 ci 280z Posted December 4, 2001 Share Posted December 4, 2001 it comes back down a little but the door is still higher than it is supposed to be. could it be that i need to adjust the door? Quote Link to comment Share on other sites More sharing options...
DavyZ Posted December 4, 2001 Share Posted December 4, 2001 On a 280Z, I would be surprised if the door did not shut (well) after you let it down. Were you using the factory jack in the proper place (there is a proper place to jack the car up BTW)??? It should not have bent the frame or the door in anyway after letting the car down. Give the car a few days of cornering and driving to see if it 'settles' any and improves the gap. Weird. Davy Quote Link to comment Share on other sites More sharing options...
Guest 400 ci 280z Posted December 4, 2001 Share Posted December 4, 2001 it isnt drivable but i jacked it upand put jack stands where the repair book said to to it at. Quote Link to comment Share on other sites More sharing options...
Guest 400 ci 280z Posted December 4, 2001 Share Posted December 4, 2001 i think it just needs to be alined because it has rubbed a little against the chrome drip rail. once i got it back on its wheels it went back to the way it was before. if someon thinks it is something else feel free to. Quote Link to comment Share on other sites More sharing options...
