Reverse flow heads?
no, if you do the extra coolant passages on the heads will dump coolant right into your lifter valley. Also, you will have to use the coolant ports on the front of the head as the crossover, because the LT1 heads don't have the crossover in the manifold.
read this thread and do everything he does:
http://www.thirdgen.org/techboard/tpi/178262-completed-lt1-heads-gen1.html
