Need some info on a turbo asap....
240zprace
It really depends on how you clock the compressor housing - In the normal position, I imagine that you will need more than 1/2 inch. My 60 trim .60ar T04E housing needed a 1/2 inch spacer to give clearance with the outlet in the 2 oclock position, looking at the inlet of the turbo.
If you clock it down at the 5 oclock position, you may be OK without a spacer.
Hope this helps a bit.
Doug
