Pop N Wood Posted January 27, 2007 Share Posted January 27, 2007 Can anyone give me a heads up on how I remove the big black plastic oil fill tube on the valve cover of my LS2? Does it screw off or do I need to pull the valve cover to get to a retaining nut or something? thanks Quote Link to comment Share on other sites More sharing options...
viperredls1z Posted January 27, 2007 Share Posted January 27, 2007 You will need to pull the cover, then it's just a matter of useing a sharp object or screwdriver or whatever it takes to move a little plastic tab from the inside. it will make sence when you see it. Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted January 27, 2007 Author Share Posted January 27, 2007 Thank you Quote Link to comment Share on other sites More sharing options...
