TC Pocket Hole Location Question
Metallicar
I have installed new 2-1/2" sq front frame rails. I am not sure if I am going to recycle the old TC Pockets or make new ones. I bolted on the engine crossmember and installed the LCA and began to second guess what the location for the pocket to be. I am worried about the rod end hole in the pocket. I know that the stock pocket angle is 34 degrees off of the frame rail. The distance that the pocket is from the LCA is dictated be the length of the Torsion Rod. My question is; is the center of the TC Rod Hole in the TC Pocket dead level with the LCA if it is level. OR do I just relax and install it so the hole is centered at 75 mm from the point at which the crossmember bolts up? Do I get any +/- in tolerance?
Thank you,
Jon
