WhiteHorizonZX Posted February 13, 2007 Share Posted February 13, 2007 http://members.iquest.net/~aca/ That's the link to Algie Composite Aircraft. I read about this in the Jan '07 C&D. This guy/company is making carbonfiber airplanes... that use the LS1/LS2/LS6 blocks anyway. I was looking through the pictures when I came across a picture of a carbon fiber oil pan for a dry sump oiling system. I figured that some of you LS guys would be super interested in this, not to mention his turbocharging system. Anyway, thought it'd do somebody some good. Pvt. Dear Quote Link to comment Share on other sites More sharing options...
Guest TeamNissan Posted February 13, 2007 Share Posted February 13, 2007 You know I saw this and was like bah another crap post but there are some really interesting pics in there lol. Esp the cnc lathe convertion. Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted February 13, 2007 Share Posted February 13, 2007 There is some gorgeous work in there. but I don't know about that dry sump for a car. I can see they could not afford the sump clearance, but there are two problems that I see. First, the oil pan is considered a structural member on an LS motor, so may need some type of girdle to pick up strength that may be lost from that carbon fibre pan. Second, unless you want to run a prop it looks like you will need to use a different pump than they do. this is their oil pump and pan Quote Link to comment Share on other sites More sharing options...
LS1 240Z Posted February 13, 2007 Share Posted February 13, 2007 where its says Algie compsite aircraft is the drysump pump and its bolted onto the rear of the motor. you could easily use this in a boat, but deffinatly cant be used in a car. Quote Link to comment Share on other sites More sharing options...
