lithium4750 Posted February 14, 2007 Share Posted February 14, 2007 I'm kind of new to the whole swapping scene. I have a 350 with a 5 speed transmission behind it. So for anyone who is doing a swap with a fuel injected motor, even on a Z, give me a little advice. I'm not exactly sure what to do with the injector harness and any of the other wiring. Quote Link to comment Share on other sites More sharing options...
V8_DatZun Posted February 15, 2007 Share Posted February 15, 2007 i got your PM.. i'd suggest you buy the JTR book.. dont know if they have one for the ZX yet but the one for the z's is helpful still.. http://www.jagsthatrun.com they have radiator... mounts... alot of things you will need. as far as wiring.. find a wire that is hot when your key switch is on.. splice into it.. (thick gauge wire that is hot w/ignition on) belive i used white/black stripe wire.. that goes to distributor. fuel pump is wired to a pressure switch for a 78-80? dodge omni or a chevrolet monza... if you go to the auto parts and say you need a 3 prong oil pressure switch they can hook you up. try to get 1/8 thread as you will have to add 1/8 adapters and T so you can use the oil pressure sending unit and the oil pressure switch. splice into (mine is a green and i think black stripped wire) the fuel pump wire and put both ends going to the oil pressure switch.. the prongs that are opposite of each other far as alternator i have no idea.. used a one wire alternator.. any more info feel free to ask. Quote Link to comment Share on other sites More sharing options...
80LS1T Posted February 16, 2007 Share Posted February 16, 2007 I have an LT1 in my 80' 280ZX. First off how good are you at reading wiring diagrams? If you can do that then modifing a stock harness is really pretty easy. Just delete what you don't need and feed power and ground to the rest. The JTR book wont really give you any info on what to do step by step but it does give you the "theory" behind the V8 swap. I didn't use it for my swap(I do have a manual though...). Guy Quote Link to comment Share on other sites More sharing options...
280zwitha383 Posted February 16, 2007 Share Posted February 16, 2007 IF you order the mounts for a ZX JTR will give you some basic instruction (what they called a rough draft for the ZX manual). They might send them to you anyway if you order the normal JTR manual and talk to them first. They're pretty nice guys. Quote Link to comment Share on other sites More sharing options...
dustin280zx Posted February 17, 2007 Share Posted February 17, 2007 I got instructions on how to place the mounts. But I think thats all i got. Its whatever instructions they have on there website. So just go to there website and read up. I dont think it has anything about wiring though. Quote Link to comment Share on other sites More sharing options...
