pjo046 Posted February 16, 2007 Share Posted February 16, 2007 I am having problems getting the rear crankshaft oil seal onto the crankshaft. I have already broken one new seal in the process, so I have ordered a new one now. Does anybody have any tips or tricks? The flange on the crankshaft is a bit uneven and slightly rusted. Can I use some sanding paper to smooth it out a bit before my second attempt? Quote Link to comment Share on other sites More sharing options...
naviathan Posted February 16, 2007 Share Posted February 16, 2007 I would takes some emry clothe and buff down any rust before trying to slide the seal over it. Put a little grease around the outside and inside of the seal before putting it on. Use a small rubber mallet and tap around it carefully to get it in. Or you could do it the right way and get the appropriate install tool listed in the FSM. Quote Link to comment Share on other sites More sharing options...
