FI wiring harness/ECU removed, Anything I need to connect?
I removed the FI wiring harness and ECU from my 76 280Z, what worries me was the fuseable links that came with it and if I need to wire anything into the now disconnected plugs or am I good to go by just having removed the harness?
Attached are pictures of the plugs under the drivers side dashboard, I identified two as the FI relay which I am assuming I can remove this relay assembly as well.
The other two plugs I am not sure of, do I need to run any new wires to these plugs?
I think I might of identified these plugs as an ignition plug in the wiring diagram, this is what I found so far:
The White/Red wire on the plug shown used to mate to the Blue #73 wire from the FI harness
The Black/Yellow wire on the plug shown used to mate to the White #76 wire from the FI harness
The Black/White wire on the plug shown used to mate mated to the White #71 wire from the FI harness
The Blue/Green wire on the plug shown used to mate to the Blue #74 wire from the FI harness
The 4th picture show the single connector from the FI harness with the White #1 wire mating to a Blue wire.
These wire colors do not mate with my wiring diagram?? does it mate with any diagrams that anybody else has?
Thanks,
Greg
2402_thumb.attach
2403_thumb.attach
2404_thumb.attach
2405_thumb.attach
