rdsk8ter Posted March 4, 2007 Share Posted March 4, 2007 If I go with twing turbos I would like them facing the same way so the piping looks the same. Can I turn the compressor 180 degrees ( The one on drivers side with the compressor on outside (by the fender) has the output facing down. Then the one on the pass side compressor on outside (by the fender) at this point the output faces up.) I would like the passenger side to face down. thanks alot im tired of racking my brain about this plumbing. Also has anyone here used a dual in intercooler with a single output or know anything about them (if they are worth a dam basically)? Quote Link to comment Share on other sites More sharing options...
Guest 280ZForce Posted March 4, 2007 Share Posted March 4, 2007 The IC piping off the turbos (hot pipe) will be going to both of the inlets of the IC, so 1 inlet for each turbo since you have 2 inlets, the 1 outlet is for the charge pipe that goes to the throttle body. Quote Link to comment Share on other sites More sharing options...
