twoeightythreez Posted March 6, 2007 Author Share Posted March 6, 2007 I'm gonna take the Z out tonight, tune a bit more (It's 15 degrees!) This should be some fun. I'll take pics of those maps. Quote Link to comment Share on other sites More sharing options...
datman Posted March 6, 2007 Share Posted March 6, 2007 Got my Spec clutch and light weight flywheel today. 515ft/lb rated so I should be good for a while. Talk to David Norton from Spec direct, he will sort you a good price Quote Link to comment Share on other sites More sharing options...
twoeightythreez Posted March 7, 2007 Author Share Posted March 7, 2007 Here's another video. 0-100mph in about 14 seconds. I mapped out approximately a quarter mile on Quebec St. The time was 0100 (GMT+7) The temperature was 17 degrees (though I later found out it was ELEVEN degrees...it was 17 deg. Fahrenheit 4 hours earlier..... I/C is working great......charge pipe to TB was still ice cold after the run.. still 7psi, and I had just driven back from showing the car off to my buddy who's into big V-8's (actually I am too but L28ET is still a grand motor) He was very impressed....his white knuckles told the whole story. I did try turning up boost for the heck of it but the T3 can only muster 11psi (keep in mind my boost gauge is plumbed to the manifold) with my huge I/C so time for an upgrade this summer! The run was done at 7psi (The efficiency is about right when it's there...even at 7psi it's struggling to provide enough air at 100mph so I believe 14's or so is all I'm getting from the stock T-3. ) Here's the video. Datman, thanks for the info! I'll check into it for sure! The clutch is slipping in 5th...the car was accelerating very quickly till I hit 5th. Quote Link to comment Share on other sites More sharing options...
twoeightythreez Posted March 7, 2007 Author Share Posted March 7, 2007 Wow....I just realized when I turned the sound all the way up...I'm getting chirps when shifting to THIRD....(at 60mph)..I'm really impressed with this little L28ET! Quote Link to comment Share on other sites More sharing options...
