Guest bouncer Posted March 5, 2007 Share Posted March 5, 2007 Hello, After reading some of posts on 283's and 327's I guess I'm one of those people that love the high reving mouse motors. So that being said, I know I will get more torque and horsepower just going to a 350 but that is not a option at this point in time. What I'm looking for is any information from anyone that has turbocharged or supercharged a 283 street engine. Head, valve, chamber, combo's. Cam spec's maybe even some dyno numbers. Thanks and Have A Great Day. Quote Link to comment Share on other sites More sharing options...
dr_hunt Posted March 5, 2007 Share Posted March 5, 2007 283 blocks are typically about as stout as warm butter. A better option would be 350 block with a short stroke, ie. 302 cubic inches. That has been done with success. Quote Link to comment Share on other sites More sharing options...
Guest bouncer Posted March 6, 2007 Share Posted March 6, 2007 Ok, 350 block and build a 302. Were would I find spacer bearings to run my forged small journal 283 crank? Where would I find 5.94 length rods to run 350 (1.561 compression height) pistons? I know the late model caprice engine ran that rod lenght but I would need spacer bearings to run them on the 283 crank. The 302 pistons are hard to find and if you do they are over $500.00 and will not work with my 60cc chamber heads. The block I have now is a 1964-66 283 cast#3834810. It has the clearence in the block for a 327 crank. Boring this block to 4.00 should not be a problem since it was used for the 283 or 327. Any help would be appreciated. Thanks. Quote Link to comment Share on other sites More sharing options...
