fl327 Posted March 16, 2002 Share Posted March 16, 2002 i was looking up bushings for a z, the diff mount bushing to be exact, and they say people use this as a diff bushing???? http://www.suspension.com/Bumpstop.htm Quote Link to comment Share on other sites More sharing options...
fl327 Posted March 16, 2002 Author Share Posted March 16, 2002 its the one in the center top row,. Quote Link to comment Share on other sites More sharing options...
Guest jcp240z Posted March 17, 2002 Share Posted March 17, 2002 That is what is typically used. Mark Sayer used sell these years ago. What you do is remove the rubber differential strap. At the top center drill a hole just large enough to pass the bump stop stud through. Use washers as spacers between the stop and the strap. A nylock on top to secure it. You'll need to unbolt the front of the diff and lower it alittle to install the strap. Then jack it up and tighten. The idea is that the bump stop loads the rubber strap. You need to lower it so that the whole thing is slightly preloaded. Quote Link to comment Share on other sites More sharing options...
