Boy from Oz Posted March 14, 2007 Share Posted March 14, 2007 Does anyone have the dimension from the outer face of one rear axle shaft to the outer face of the other rear axle shaft on a 3/73 240Z (2 seater). My car is stripped to the shell at the moment and I'm trying to work out some wheel off-set options. Thanks Quote Link to comment Share on other sites More sharing options...
COZY Z COLE Posted March 14, 2007 Share Posted March 14, 2007 This might help....http://forums.hybridz.org/showthread.php?t=100401 LARRY Quote Link to comment Share on other sites More sharing options...
Boy from Oz Posted March 15, 2007 Author Share Posted March 15, 2007 Thanks. I tried that before posting. It gives the rear track at 1347mm but I've always assumed that measured from the centres of the wheels. That's probably fairly close but I would like to be sure. Quote Link to comment Share on other sites More sharing options...
johnc Posted March 15, 2007 Share Posted March 15, 2007 Well, I have a late 1972 on the rack now but the dimension you're asking about changes with ride height, camber, and rear toe. I can give you the number at full droop, on a car with shortened struts, camber plates, and aluminum offset inner LCA bushings: 40.563" Quote Link to comment Share on other sites More sharing options...
