5 lug s130 update swap
Well it is getting together i seam welded the rear sub frame and trailing arms.. swapped the bushings for poly ones .. and test fitted my 17" 10 J
not a bad lip!
and from testing it seems to work out fine
here is a picture of the rim with arm attached and a brake disk in between, it space it clear of the arm.
Sofar they only thing that can go wrong is the filler neck as far as i can tell, but that would be a sign i have to get a fuel cell sooner than i wanted ;)
My OBX HLSD is all done aswel.
I plan on using a MSA sway bar kit with end links. this way i have minimum rubber and polyurethane.
Next week 300zx cv axles and bolting up the rear sub frame so it is ready to be swapped on the car
Hey Frank, are you going to be using a handbrake with your set up? over here we have to keep it for street use and i havent managed to find something to replace the stock setup, was hoping for something to fill up my 18" wheels.
Nothing Vinh... they are the exact same lengt.. for the front however you need to adapt the arms.
These are two strengthened and seam welded front control arms, we measured that they needed a 25 MM extension for my 8,5 to fall within the fenders top and clean up the camber issues involved with running a z31.
Thanks VA-Motorsports!!(my friends shop) i keep learning from them:038:
Only they would TIG weld for costumers etc .. but watch and learn from teh pro's!it is great to watch and learn to think that motor sport way
