280zx under heavy mods
rdsk8ter
body work has started here are some pics more to come let me know what you think
3 peice wing yes its the z not the zx wing
cowl
front bumper mods to mas type 2
shaven rear with molded out part at the bottem to match msa type 2 body kit
front bumper again
side cowl i need to finish it still
custom dash
lots of pics shows how far it will come
  • 1 year later...
  • 5 months later...
Got the mount done for the turbo today now I just need to cut open the base and adapt it to a 3" pipe shouldnt be to bad..... or will it lol. I got a buddy grabing me my v band and pipe for the charge side and the hot side 5" pipe witch I will adapt down as quickly as possible to 4" once under the car it goes into 4" oval pipe. I am starting to get really excited about this build (thank god I was starting to loose motivation lol. Also I have the fabric on order to finish up the interrior stuffage lol. will post more pics as they come.
I got my turbo feed pipe started heres some pics. I will smooth the welds out later but just getting everything fitted for now and checking for leaks tomorrow ( I should say fixing leaks tommorrow lol theres gotta be some but its late and I'm tired).
Heres a picture to show how the pipes merge together. They are open in the center. I still have got to grind down the extra metal inside but my neighbors would kill me if kicked on the die grinder now lol
Please dont make fun of my welds, the only welder I have to use doent have gas lol. They are not very sexy but I got good strong welds there.
I got some more done on the hotside feed pipe. I still need to add the wastegate tube though. That being said what size pipe is ideal for this? Also I know I need to leave the main tube at a 45 degree angle but can I have anouther 45 degree ish (depending on what bend is needed to have the wastegate level) in the same pipe?
Here is what I have so Far
Well got the down pipe almost done I need to go through and clean everything up down pipe headers charge pipe etc etc and get them ready for ceramic coating. Here is how Im going to be running the charge pipe. Picked up some mandrel bend 3" aluminum 90s at a killer price
Down pipe to 4" v band flange
Charge pipe
Pardon the pipe not lining up but heres what Im going to do with the last part to the intake.
Now i just need to find someone to weld aluminum for free......lol
Ive got the pipe mocked up just need to get the flange. Here are two locations I'm considering (I held a peice of pipe to see rough size. pipe is longer then BOV but it gets you the idea.
Here it is visable
Here it is not
I dont Know where I should put this Im up for ideas too.
Here are some Pics Of the Pipe yes It will be into the intake. The new intake Is slightly lower.
Next is fun with heat shields and wrap lol.
