How much play in my R200 is acceptable
24OZ
Hi there,
I have just fitted my 240Z halfshafts to an R200 that I picked up and i noticed that when i pull the halfshafts in and out there is actual movement inside the diff, I can see the diff's flanges move a couple of mm's in and out.
Should there be any movement at all?
I'm just curious about this as I will probably just fit it and see but wanted to run it past you guys in case you had any thoughts or advice.
Thanks
