Guest TAlchemist Posted April 5, 2002 Share Posted April 5, 2002 everyone seems to answer the question of the biggest tires that will fit inside the wells without flares... i want to know the biggest tires < width wise > that will fight in the tire well except that i want them as far past the fenders as possible. i dont mean spacers to make them wider but the like 10 inch wide tires that will fit correctly on the inside and i dont care how far out they go. thanks Quote Link to comment Share on other sites More sharing options...
Guest Aaron Posted April 5, 2002 Share Posted April 5, 2002 If I remember correctly from the driver manual, in AL nothing can protrude more than 3" from the widest part of the body. If I Remember correctly, several people here have 8.5" tires inside the fenders (correct me on this), so if you want the tires to stick out, you should be able to go 11.5". The problem will be that the Z squats A LOT , and the tires will rub under any acceleration or braking. Quote Link to comment Share on other sites More sharing options...
pparaska Posted April 5, 2002 Share Posted April 5, 2002 check out the FAQ : http://240z.jeromio.com/faqdraft/ Note that the first example is my car. The link to my site is broken. It should be: http://mywebpages.comcast.net/pparaska/wheelstires.htm The details for getting this to fit are there. 255/45-17 on a 17x9" rim, no flares, rolled fender lip, 8" coilovers. Quote Link to comment Share on other sites More sharing options...
