lt1 fan to relay wiring...relay pin#
the pcm red connector pin11 is what turns on the fan, i was told this wire connects to the relays ground pin#85, pin#86 is ignition hot and pin#88 is constant hot. then where does pin#30 on the relay go to???
im using a basic 30amp 4 prong relay. has small # 87-86-85 and #30 marking the pins
or is this the correct way to wire it...
red pcm connector #11 connects to pin#30 on relay
pin#85 is regular ground (chasis)
pin#87 is constant hot
i was told pcm red connector pin#11 connects to ground on relay to turn on the relay. the #11 pin on pcm, is that a neg or pos?
The LT1 PCM relay wiring is deffinetly confusing. I didn't wire my up right the first time either. Here's how it should be though if I remember correctly....
PIN 85- Comes from pin A11 on PCM(ground through PCM)
PIN 86- is power from IGN 12+ (10A fuse)
PIN 87- is the power feed wire for your fan
PIN 30- is power through a fuseable link from BATTERY+
Then all you need to do is connect a ground wire on the other side of your fan wiring.(This is for a single speed fan by the way).
Here's some good info for LT1 wiring and relay wiring....
http://www.the12volt.com/relays/relays.asp
http://www.datsun-280zx-lt1.com/LT1_WIRING_INFO.html
Guy
