fuel pressure boost
4znova1
I know you hate searching...
but 10psi without an intercooler
12-13psi with an intercooler.
sure you can run 15psi if everything runs smoothly.. have an AFR guage or detonation detector?! I would recommend using one unless you like rebuilding your engine.. since you have a metal head gasket your pistons skirts or rings will blow first.
By the way what is your FMU (RRFPR) ratio?! 1:1? 1:2? it will make a difference on fuel pressure.
