MS question NOT FOR MY Z
383 240z
I'm -squirting my DD. a 4.2l Jeep. for the injectors should I run 2 banks of 3 injectors each back to the v-3 board? I'm using High Imedence injectors, I tried to search for the answer but I could not come up with a thread that answered my question. I'm not even sure if it matters but I figure spread the load out as much as I can. Thanks a bunch guys, Keith
Yep, two banks of three. You can either have one controlling the front three and the other controlling the back three (that's how I have my Dodge Dart set up) or have one driver controlling the odd numbers and one controlling the evens. I've heard the odd-even order is often best, but there's some controversy over which one is the optimal setup. I suspect different combinations work better on different engines.
Thanks I wired inj 123 and inj 456. I figure on a motor this old it wont make difference. It has 200k+ but just wont die. A 4.6l stroker is going in when it does, this way I'll have the efi and spark control all installed and sorted out before the new motor. Thanks again Keith
