Manual Tranny, RB20DET, oil capacity
jerryb
to the fill hole is the proper way but you won't have any problems if you put 3 quarts in there, i have the fsm but i'm too much of a lazy bastard to go look it up, and i always put just shy of 3 qts in em and never have problems. i believe the proper spec should be around 2.75qts. it calls for 75w-90 but i would STRONGLY recommend 75w-140 synthetic (the only way i've ever found that was in synthetic), when the car's ice cold it'll be a little notchy shifting, but i've known a lot of trannies to mess up with 75w-90, and zero to mess up with 75w-140
