dragoontwo Posted April 8, 2007 Share Posted April 8, 2007 I'm in the process of squirting a '82 zxt, but here's the catch.... the car I had bought has very little wiring in it. it doesn't even have the wires for the battery terminals. I have an '82 zxt parts car with everything in it. now my question is, what wiring do I actually need to transfer? I'm going to build my harness for the ms on the car, so I just need to know what I need to get power from the key to the ms. I'm going to wire the fuel pump in with the relay board, and I'm going to be using the wheel decoder for edis directly instead of using the ford unit. thanks, Mike Quote Link to comment Share on other sites More sharing options...
gearheadstik Posted April 8, 2007 Share Posted April 8, 2007 A switched ignition wire is all you will need... probably a black w white stripe wire under the steering. Quote Link to comment Share on other sites More sharing options...
dragoontwo Posted April 8, 2007 Author Share Posted April 8, 2007 I think I've got it.... after being away from the problem for a bit, and talking to tonyd, my problem isn't really a problem. I did not realize where the battery voltage went to to power everything, and I should be straight now. I've moved the fusable link box to the good car, and everything should now be ok. Quote Link to comment Share on other sites More sharing options...
