Guest firebern Posted April 22, 2002 Share Posted April 22, 2002 I bougth some camber bushings for my V8 Z cause I cannot afford to go with the real thing before next year. Are those any good? Can they slack off while I am riding? I want to set the camber once and that's it never think about it again. Fire Quote Link to comment Share on other sites More sharing options...
blueovalz Posted April 23, 2002 Share Posted April 23, 2002 If you are making reference to the delrin/aluminum bushings, then you will have a very limited range to work with. They will maintain the setting you put in them, but, even with liberal amounts of grease, they will develope some wear, and slack in the bushings, causing a small amount of racket in bumpy situations. I had mine on my street car for a couple of years before finally redrilling the crossmember. At least a that point, I knew exactly where I wanted the pivot point to be. The rear ones where the ones that wore out the quickest. My suggestion would be to use that real sticky grease that aftermarket sway bar bushing manufacturers use between the poly bushings, and the bar. This stuff will stay put a lot longer than anything else out there. Quote Link to comment Share on other sites More sharing options...
Guest firebern Posted April 23, 2002 Share Posted April 23, 2002 I have the Motorsports bushings. They are the same. I'll get some of that grease and see how long they last then. Thanks, Fire. Quote Link to comment Share on other sites More sharing options...
