Tech is not a problem. But they will not hook.
You would be better off with your street Radials.
The Side walls on a round track slick are extreamly stiff and the compound is way to hard for drag racing. If you cant get Drag Slicks lower your tire psi to around 20-25 on your street tires and drive around the water. Do a light burnout with out the water and you will be better off than with the roundy round stuff.
Daw I would like it if you could let me know when you are going to the track. I would love to see how a Z goes down the track. I trust that you would be going to pacific raceways (was SIR) to run it and it is right close to my house if you were to need anything.
DP
