Spring rates question?
Guest zfan
Guest zfan
Does anyone know what the stock spring weight was for the front and rear springs in a 1971 240 Z. Im trying to go a little stiffer than stock but do not want to over do it!
Thanks,
Mike
The stock spring rates front and rear for the 240Z was 90 lb/in.
I am autocrossing my 260 and am using 250 lb/in in the rear, and 200 lb/in on the front. This is too stiff for the street. For the street try 150 lb/in in front, and 175 lb/ in in the rear.
Guest scca
as an idea the suspension tech springs are bout 140lbs....
like dan suggested 150 front 175 rear or 175-200 if you drive it hard
Guest Aaron
I remember from my old service manual that the '81 280ZXT was 120lb on all four corners. I was a much heavier car however.
